in need of a cam angel sensor
boostedrb
Car: 91 240sx fully buit rb25det
i was informed over the week that the cams i have for my rb25 will not work unless i get a hitachi cam angel sensor (CAS). so if anyone has an extra laying around please let me know or could point me in the right direction to get one. thanks.
bmxarmy
Car: 1961 AMC Rambler
I will look at the one I have from the rbambler. series 2 rb25
boostedrb
let me kno if it says hitachi on it... thanks
chad b.
Car: chocolate chip kouki
What cams are you running that you have to have a Hitachi c.a.s.?
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
To probably shead some light on situations like this...
Many retailers (and resalers) unfamiliar with RB engines that sell RB parts identify RB25 Series 2 engines to camshafts that are labled "Series 2".
The problem that exsist is that when a camshaft manufacturer (ie: Tomei) labled their camshafts "series 2" they ment for the 2nd style of cam angle sensor (CAS) that was used during the RB production period (re: R34 style Hitachi manufactured CAS or better known to the RB guys as the NEO style CAS).
The drives of the two CAS are different and thus require a different style camshaft.
There are other non-NEO RB25's that use this style CAS as well. Along with the R34 RB26's.
So in a nut shell... when purchasing camshafts its not based on the engine series but rather the cam angle sensor your engine is equipped with.
To clear up any confusion for those searching on this topic later...
GL
boostedrb
exactly wat coolwhip said... my cams r hks cams... they need the hitachi cas. the one i have stock on my car will not work... so i need the hitachi one asap
boostedrb
so has anyone found out where i can get that hitachi sensor from.... need one asap please...
S14-NEO
Car: 1995 nissan 240sx RB25 NEO powered
im pretty sure ive got one , ill let you know when i get off from work
boostedrb
yes please s14 neo, it would be greatly appreciated... let me kno if its the hitachi one please and thank you..
S14-NEO
well as of right now i have not had any luck finding it, but i will keep looking for you
boostedrb
ok bro just keep me posted
boostedrb
can anyone else help me please
bmxarmy
I just checked mine, It doesn't say hitachi on it anywere, It looks like it has a mitsubishi logo on the center front and some numbers are etched in the side.
sorry pal.
nolan
boostedrb
bmxarmy wat does the front side look like... the shaft that goes into where the cam is... is it a slit or look like a star???
bmxarmy
Star
boostedrb
Yea that'd not the one... thanks for looking on it bro...
