Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Thu Apr 17, 2008 10:13 am
That's gonna be a toughy to find. But I think WestCo will be your best bet. They can usually order anything off the JDM catalogue for you if you're willing to wait. Your other option is to find someone parting a motor out.
If you're good with welding, I suppose you could fab up the hard lines. They don't necessarily have to be bolted to the block. They do that to cut down on having the hoses vibrating loose. You could take some straight pipe of the correct diameter and with a few nipples, fab it up.
I would be hesitant to run straight hoses back because those lines have all the heater lines for the IACV, sensor housing, and the turbo.
