tmorgan4 »
https://forums.nicoclub.com/tmorgan4-u52698.html
Wed Oct 15, 2008 6:27 am
The "rack" I'm using is actually a ram. With the fully-hydraulic systems (often referred to as full-hydro in the 4x4 world) a double ended hydraulic ram with no mechanical steering connections is what turns the wheels. What you can't see in the picture is two hose connections (one for left, one for right).
Here's a poor picture of my current setup:
The specs on the pump I'm using currently fit somewhere in here. It's difficult to find the exact output as many different pump variations exist and many contain modifications to increase both the pressure as well as flow. This type of pump is commonly known as a P-pump and came from the factory in many larger 4x4 trucks and SUVs.
The pressure mentioned in the above spec sheet lists the P-pump at 1200-1300psi. According to the FSM, an OEM Q45 pump (without HICAS) lists a maximum pressure of 1109-1194psi. I'd imagine this should be sufficient and translates into how much force the ram can output to turn the tires.
As long as a Q45 pump could sufficiently flow 3.1-3.5GPM like the P-pump it would work perfectly. Does this seem like a reasonable number?
Thanks!
