Quach »
https://forums.nicoclub.com/quach-u21454.html
Mon Jan 24, 2005 12:27 pm
my clutch isnt holding any pressure, as in it isnt coming back up by itself when i depress it. my clutch master cylinder had a leak in it that i was going to fix about a week ago. i bought a new MC and attempted to install it, but i ended up stripping my clutch line nut early before i thought to buy that special wrench you use . so since i was unable to take the master cylinder off without taking the whole clutch line along with it, i decided i would rebuild the old MC with the internals from the new one. i did that, did all my adjustments to factory specs, and proceeded to bleed the system. i bled it numerous times, i bled both the clutch dampener and slave, as well as both at the same time and now there are no bubbles, but the clutch holds no pressure. the clutch doesnt come back up unless i pull it up myself. i bought a different rebuild kit, and rebuilt the MC again, but that didnt fix the problem. i tried bleeding it over and over, and still no pressure. im stumped. ive been told that i can bench bleed the master cylinder? i couldnt find any writeups that included anything that i havnt done already. is there a way to bench bleed the master cylinder? i would remove the clutch dampener and replace the slave, but my car is non-op right now seeing as the clutch wont disengage, so i cant move it somewhere where i can lift the car up. any suggestions? this is really anoying me, i havnt driven my car in more than a week, and ive been too busy and broke to go through the trial and error process. please help me!
