Hi, I'm looking at adding the Pioneer AVIC-F700BT w/ Backup Camera and XM in my Rogue S and have a few questions:
http://www.pioneerusa.com/PUSA...700BTh ... SA...920XM
1. Does anyone know if the Radio/Bluetooth controls on the Steering wheel are added to the existing wheel (a possible orderable part) or if the whole steering wheel is replaced.
2. Is it possible to order the XM roof antenna and/or the microphone that goes in the maplight area from the dealer (or if that mic would even work with the pioneer radios). I'd like to keep the car looking at stock as possible.
3. Do you think there would be a significant difference in going with four 3-way speakers or changing the fronts to a component system w/tweeters under the dash grilles to have 6 speakers. Keep in mind that I don't want to have to add an amp (I don't play the radio at high volumes or desire a ton of bass). Also, for the people that already replaced their radios, are the stock speakers worth keeping? I'm sure most of the horrible sound is from the crippled stock radio. Here is what I'm looking at below:
3-way Front Speakers:
http://www.pioneerusa.com/PUSA...6972R
Component Front Speakers:
http://www.pioneerusa.com/PUSA...tab=B
3-way Rear Speakers:
http://www.pioneerusa.com/PUSA...1672R
4. For the dash kit, has anyone seen the Scosche kit yet? I've read on the forum that people like them better then the metra kits.
http://www.scosche.com/products/productID/1645
5. Lastly, does anyone see a problem (generally) with going with Firedog at Circuit City to do the install or should I seek out a local car audio specialist (I live in the philadelphia area). They warranty the install for life and will even put back the stock radio for free down the road if you need to. Circuit City does carry the F700 and all the parts I would add so they should be familiar with them. I will, however, buy all the stuff online and save a few hundred dollars.
Sorry for the long post, maybe I should have broken it up...
