In case you find yoru brake lights stuck ON.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
I found the little rubber button attached to the brake pedal responsible for pressing the brake light switch had crumbled and popped out. With nothing to push the button the lights remained on all afternoon before I noticed them.
Quick fix: M6x1" bolt, M6 lock washer, M6 washer and M6 nut. Install that combo into the hole where the rubber plug once lived. Problem solved permanently.
Thanks for reading!
Mods can you fix the spelling of the title? Please and Thanks:)
PEZi
mine came on every once and a while... turned out i was a little low on fluid... another easy fix
