Edub1 wrote:
IIRC as a rule HP begins to exceed torque somewhere near 4500RPM or so.
One guy with a Mustang dyno was telling me that Dynojets are notoriously inacurate and that they seriously inflate power figures. He was saying that it's not unussual for cars to show more than 50HP less on his Mustang.
At any rate, the theoretical max for 8lbs with the rest of the motor unchanged is 239HP. 1.54ATM(155HP)=239.35HP
Perhaps if he dynoed his car at -30* it might add 60HP.
Its 5252rpm.
Yea and dynojet guys say mustang dynos are dumb because all the people that use them just ***** about how dynojets are inaccurate.. It so ****ing retarded.. I get so sick of that ****.. Dynos are for tuning.. I'd rather tune on a mustang dyno, but when I go for numbers, I'm going to a dynojet because thats what everyone else uses..
When I want to know if my car is faster than someone else's, I'm going to the track to get a trap speed..
And your calculation isn't right.. pressure affects flow. Horsepower is proportional to flow, but you should multiply the flow of an engine by the pressure ratio because horsepower can be affected by other things. The KA has a pretty crappy tune stock, and it is most often cleared up by performance tunes when you boost the engine. If you calculate the flow of the KA at 5800rpm and factor in the 1.54 pressure ratio, you get 26lb/min which equates to 260bhp. And most of these calculations are too outdated to be accurate on today's engines.. Using these calculations as simple as we are, we assume 100%efficiency and they still average low..
