In-cabin microfilter replacment
rocnrol
Car: 2007 Nissan Altima
I need to replace the in-cabin microfilter in my 2007 Altima. I've tried removing the glovebox liner without success. I don't want to force it and risk damaging it. Any assistance with this removal/replacement is appreciated. Help!
Mr.Coupe
Car: 08 Altima Coupe 3.5 BOOSTED
I haven't had to do this to my car yet, but I have done it to my 05 Frontier LE. Here is a link that gives instructions on how to change it on an 08 Altima Coupe, which shouldn't be different then your 07. I hope it helps you. GL and please post if it was a success.
http://forums.altimas.org/zerothread/352914
Ricky C.
dangeris
Car: 08 Code Red 3.5
08 BMW 328xi Coupe
90 300ZX 2+0 NA
Thanks Ricky..I was about to point to the same link. I just made this into an article too..
marlin29311
Car: 2008 Infiniti G35x
Once you have out all the screws just give it a good yank! It'll come out with no problems....read the DIY!
Marisha
Car: 2008 Altima Coupe 2.5S
I don't know about the sedan, but in the coupe I was able to switch out the in-cabin filter without taking out the glove box. If you can somehow reach behind the glove box and take the tab holding the filter compartment closed out, you can then grab the tab on the filter and yank it out. Then through wonderful contortions you can put a new one in and close the tab. Bit of warning though, I ended up upside down in the passenger seat with my head under the glove box for most of the time trying to get this to work.
08Coupe
Marisha wrote:I don't know about the sedan, but in the coupe I was able to switch out the in-cabin filter without taking out the glove box. If you can somehow reach behind the glove box and take the tab holding the filter compartment closed out, you can then grab the tab on the filter and yank it out. Then through wonderful contortions you can put a new one in and close the tab. Bit of warning though, I ended up upside down in the passenger seat with my head under the glove box for most of the time trying to get this to work.
OK I'll say it.... Pics??
