glitched wrote:Hmm, my car had the same symptoms of the air temp not being warm enough on 3 and 4... however when the water pump died and I got a new one, the symptoms went away...
Lifetime warranty on my water pump ftw.
modulation wrote:A few things..
#1. Most Likely there is still air in your heater core from when you messed with coolant system. Put car on ramps so radiator cap is highest, take off radiator cap, let car get up to temp and make sure heater is turned on..
If #1 isn't it (which I think it is since it's most likely):#2. There is a baffel that is moved by the vacuum system which allows the air to blow threw the heater core area or not. Perhaps this isn't working?When you move the lever from cold to hot does anything happen (noise, etc?)Or is the air like the same temp no matter what side it's on?
#3. Did you buy the car used? Perhaps they did a heater core bypass on it?
I am not too familiar with this heater core bypass you speak of but there are lines going to and coming from the heater core. I will try to bleed the cooling system with the car on jackstands tomorrow and report back... There are no odd noises when moving the temp selector from hot to cold. The heat works fine if I have 1 or 2 selected. 3 and 4 are the bad ones... The air is warmer when the slider is towards hot but it's definitely not warming my car up like it should. I am thinking it is probably an air pocket in my cooling system because the heat definitely gets warmer when I rev the engine. I know that is a symptom of an air pocket. Like I said I'll bleed the system tomorrow and report back.
