IN CABIN FUEL PRESSURE GAUGE INSTALL
slider78
Car: 1990 240sx
HELLO EVERYONE, CAN SOMEONE TELL ME WHERE IS THE BEST PLACE TO HOOK UP A FPG ON THE FUEL RAIL OF A RB20 AND WHAT TYPE OF ADAPTER YOU GUYS HAVE USED, I COULDNT FIND ANYTHING ON THE RAIL TO TAP IN TO, EXCEPT MAY BE USE A "T" ADAPTER JUST BEFORE THE FUEL RAIL LINE, IS THIS WHAT EVERYONE HAVE USED, I BOUGHT A MECHANICAL GAUGE. THANKS EVERYONE FOR ALL THE INFO YOU GUYS POST, IT HELPS ALOT. THANKS AGAIN.
Joe
you want to run gasoline into the cabin?
use stainless steel braided lines. only help i can give you.
and please dont make posts in all caps. its annoying. thanks.
slider78
Car: 1990 240sx
I have everything I need, including steel brainded line, but my question was...where do you hook up the adapter, which would be a "T" I guess. I apolgize if I anoy any one here, it is not my intention.
slider78
Car: 1990 240sx
my car is shutting off and I thought i'd be a good idea to install a fuel pressure gauge, so that I can rule out the f. pump.
240z4u
Car: '95 Nissan 240SX
If you attempt to tech at any drag strip they will give you a no go due to fuel run into the cabin.
You can tap in anywhere in the feed line.
Evan
uber95
Car: S14
Do not run any fuel line into your cabin..Period..Spend the approximately $200.00+ it will cost to get an electric F/P gauge with sender if you have to have your F/P inside the cabin..Such as http://cgi.ebay.com/ebaymotors...wItemBe sure and get the sending unit as well or the gauge will be useless..That's just my suggestion, you can do anything you feel safe doing...
240z4u
Uber is right.
I have an autometer phantom electronic sender FP gauge that I can sell you if your interested.
Email me if it sounds like something you want.
Evan
schanne
Car: 93 Hatch-Sr20
NO GAS IN CABIN!
StricNyne
gas in cabin = retarted, i had friends that ran oil and fuel, instead of buying electronic gauges
slider78
Car: 1990 240sx
wow, thanks alot guys, this is really good advise...may be the best I can get. thanks again...I will not run a fuel line inside the car. thanks again.
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
Fuel + Oil in cabin == firey death.
slider78
Car: 1990 240sx
guys, call me what ever you'd like but I thought this was the best way, but now thanks to the good advise of all you guys I will spend the extra money I need to spend and do it safe. thanks again
StricNyne
yah prosport gauges r ok and new STRI are awesome, they are under 150 per gauge and have a awesome start up sequence
slider78
Car: 1990 240sx
cool, price is a big issue, autometer is nice but expensive. thanks
