In a bind, need advice...
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
I have a meet to go to in march (already payed $100 registration) but i have a problem. I have a s15 turbo but the stock fuel system at the moment. At 7 psi will I run into problems using the stock ECU and fuel injectors? If its going to be a problem i will get a apexi SAFC and put in my sard 550cc (that i want to sell), but i would rather save for the powerFC and put off the fuel system for now.
Phax
Car: Control dynamics
You can run the T28 at 7psi and be fine. You don't need more fuel until you start running more boost.
nnkfws333
Car: 2004 Infiniti G35 and a 1989 Nissan 240SX
How much do you want for the injectors? Do they fit in the stock fuel rail? Can I aim? Im just curious to asking questions on your setup thanks!
Onizuka
Im not selling them yet, if the Quad throttle bodies dont work out for me im going to need these for my stock intake mani and fuel rail (the new manifold comes with 440 topfeeds and rail).
AIM: Fiss240
Cyberkreig
Car: 1993 Nissan 240SX SR
Technicaly the t28 should be more efficient even at 7psi, but thats what a mass air sensor is for. It should run just fine until you over run the stock fuelsystems ability
Onizuka
so when im on the track ringing my engine out to the redline i wont have any problems?
Cyberkreig
I wouldnt think as long as you are modest on the boost. Just do your rice math. here is what i mean.. this is all just a guesstimation:
T25 tops out at around 280hp @14-15 psiT28 tops out at around 320?hp @ 14-15? psi
280/14 = 20hp/psi320/14 = 22.86hp/psi
the t28 makes a guestimated 2.86 hp/psi more than the t25. @ 7psi you will make approximately 20 hp more than stock. This is WELL within the 370cc injectors limits.
I KNOW its not an exact science, but its good enough to be sure you wont miff anything up.
chrispy
Car: 1990 Nissan 240SX HB
i have no problems running the big28 without the Z32 MAF, or bigger injectors so far. The only thing i notice is that at about 6500-6700 RPM the MAF is running at about 97-98%. SO i have never taken her above that RPM cause i figure without a bigger MAF the air flow would be the same at 6500 as it would be at 7500 , which shouldnt be.
compression
the 370's are not going to support over 300 hp. The factory ECU limits duty cycle to about 80%, which is a good&safe thing. Go to the RC engineering website and do the online calculator, that should give you a good ballpark of what injectors to use. I seriously doubt the factory 370's are going to support over 13 psi. Just watch your AFR, make sure you dont jump lean at the top end.Heres an example:300HP, .62 BSFC(for turbo engines), 50 psi fuel press., 85% duty cycle, 4 injectors = 536cc/min.
for 250Hp and the above params = 447cc/min
for 207 HP = 370 cc/min
hope that helps.
Onizuka
Well i know people have put down over 240 at the wheels on the stock injectors. What im asking is: will my T28 flow enough at 7 psi to max out the stock injectors?
MainEvent212
Car: 95 Nissan 240SX SE w/ SR20DET+goodies
i doubt it...how much did you pay for that s15 turbo anyhow? i've gotten my sr swapped in and i'm already feelin the itch lol
Cyberkreig
anyway, an S15 turbo is sounding mighty tastey
Onizuka
MainEvent212 wrote:i doubt it...how much did you pay for that s15 turbo anyhow? i've gotten my sr swapped in and i'm already feelin the itch lol
new $850 shipped from private seller in BST, its like $865 from phase2 though :)
Hijacker
Car: '92 240sx Convertible
'94 F-150
J-Spec Tuner wrote:Well i know people have put down over 240 at the wheels on the stock injectors. What im asking is: will my T28 flow enough at 7 psi to max out the stock injectors?
lemme say it: No. If I haven't maxed out my stock injectors on 12 PSI even with my old T25, I doubt that 7 PSI on the T28 will max them out.
Phax
:Werd
