This is my second z32 and I have been researching these cars for many years now, so I know many of the technical aspects to what is required outside of purely race-technology parts for this build.
Onto the car itself. She is a 1990 2+0 N/A T-top, which was converted to a slicktop TT, Fully caged and stripped, full fiberglass front panels, SM-Z body kit, fully-functional brake ducting. In its day it was powered by a VG30DETT built to around 650hp, fully scavenged oil system, fuel surge tank and coolant swirl tank. It retained its N/A rear end with seven different oil-cooled diffs, each geared differently for track layouts. Because it also never ran headlights, the entire intake/boost piping was custom made to run through the headlight buckets and into custom made Stillen Inter-coolers.
The idea of this build is to bring back to its former race-spec glory, with minor changes to allow for it to be driven on the street (modified intrusion bars, wiring, lighting, heat) without affecting its track potential. She will be overbuilt in any area possible for the power I will want to push with her final engine (600hp-low boost, 900hp-full tune)
I'm sure any questions will remind me of things I may have missed or not explained fully, and many of you might recognize the car. I have done a ton of research to find any info possible on the car and where it went after IMSA to end up in my posession. Time for pics to thank you for reading what is hopefully going to be a very successful resurrection of this Chassis.
Here are the two best pictures I can find of her in her prime and at work
Thanks for reading!
