Improvements since 2003?
Nissan 350z / Nissan 370z general community discussion forum
Peterofdevon
Car: 94T 70K, miss mannors, 96 Black on Black 72K, raw sex
Hi Guys,
What are the (major) improvements since 03. I have a lust for the maroon (brickyard) body color. I saw one last year and cannot get it out of my head.
As much as I want a M45s this may be the better bargin.
Thanks for your thoughts!
Peter
jEzTeR
Car: '07 Infiniti FX35
'02 Nissan Altima SE 3.5
'93 Nissan 240SX Hatch
Brickyard(only mad in 03) is the best color IMO!
Tire wear was bad a whole lot of the 03's.
Ho many miles does it have on it?
Exar-Kun
Car: 2005 350Z
the tire thing, and IMO the transmission issues, were the only two things I'd be concerned about. YOu can probably get your transmission swapped under warranty, if you find a good service guy.
-Chet
radmar1
Car: 91 mr2, 01 galant, and trying to get a 240
what goes wrong on the tires and transmission
Exar-Kun
Car: 2005 350Z
THe tires weren't "wrong" but the alignment specs were a bit agressive, and the RE040 Bridgestones have crap for outer shoulder stability, so the tires feather and wear out...
The transmission has some issues up to 2004.5, the coutner balance shaft (IIRC) is in a differnet place, and the gears aren't reinforced like in the 04.5+. Most people's problems, from what I can find, are with doing mods and using GL-5 (a HUGE NO-NO) in the nissan transmission...
But I still like the stronger gearbox in the 05+
-Chet
C-Kwik
The 06 has a lot of nice minor changes. The interior looks nicer. The nav equipped versions delete the lame door that is hard to close and the controls look to be laid out a bit better.
Might be moot for you though as it sounds like you may be looking for used one anyways.
As an additional note though, the 06 has a new color - interlagos fire. I saw one but it was indoor and I didn't realize it was a color shifting paint. But it looks a lot like brickyard indoors. Perhaps a tad redder.
Return to “350z / 370z Discussion”
