Jacko3 wrote:Beancooker:
10% more Nitrogen could be a deal breaker. As far as i am concerned, my cars stability on the road has improved dramatically. While i know that air contains about 70%+ Nitrogen, you can't rule out the effect of an additional 2o+% Nitrogen in replacing the other gases in air.
I know it is hard to beleive, why don't you try it and see if you like it or not? It won't hurt anything. Worse case scenario, you can remove it and replace with air. I am very confident that my car's handling improved with the pure Nitrogen in the tires. Try it and see.
They put it in the tires that I just got. I told them to put it in the fronts if they are doing the rears also. They did, and it was free too.
Makes absolutely no difference whatsoever. The only difference that I noticed is that I had to go back, and have them put more in, since they only put 35psi in her. I like it at about 42.
Been driving it same as I always have, and haven't noticed anything yet.
Maybe if I get on 101 and head north, I might notice it, however I think I'll notice the better grip of the wider tires, over anything that the nitrogen offers.
Jacko, I just thought of something, what were your tires pressurized at before the nitrogen, and what about after?
If you ran say, 42psi with air, and they filled the tires to 35 psi with nitrogen, then you will notice it "sticking" to the road better. But if the pressure is equal, I can't see where the difference is.
I noticed right away when they only had 35 psi. The ride wasn't stiff/bumpy enough. It also stuck to the road, and probably would handle a little bit better, but I'm stuck in my ways of 42 psi.
