Hah! I raised this thread from the depths!F1SportsFan wrote:So if it's six bolts all the way around, is it good to go? Does the R230 and R200 mount up the same?
EDIT: Looks like they are not interchangeable according to this post: zerothread?id=311788 Back to the R200.
Modified by F1SportsFan at 2:32 PM 12/30/2008
90-96 300zx TT diff is 3.69 VLSD and six bolt all the way around and should bolt up to a 03-05 M45 with only needing to mess with the 2 mounting points in the from using larger or smaller washers.
Obviously do this at your own risk - but it looks like alex had not trouble fitting it up in there.
Good luck!
