impossible to put car into gear with clutch-help please
89porkchop
Car: 89 240sx
ok bought a project car.had no slave installed new one along with new clutch master cylinder.i can dry shift the transmission with no power to the car.if i turn the car on and try to shift nothing.it's super hard to press pedal down.did i not adjust something correctly?
180fan
Car: 89 fastback
did you bleed the line after installing that new gear
did you also do anything to the clutch while you were doing this process
was the previous owner able to give you any insight on the project? like did he/she try installing a new clutch and just happen to not put the fork in the wrong place on the throw out bearing carrier, and so on?
