impossible to get into 1st gear
zoomer0
Car: 97 altima
97 altima,always having difficulty getting it into 1st- manual trans. but when i shut the eng off , it slides right into gear wtf can be wrong?
s13sr20chris
all other gears are ok? if so its either a synchro or a shift fork.
benemorius
Car: s13, s13, eg, e36
It's so very early in the morning, but I do believe that if shutting off the engine affects it in any way then your clutch would have to be not fully disengaging when you put the pedal in. Check to see whether your clutch is operating properly.
Prelude Guy
benemorius wrote:It's so very early in the morning, but I do believe that if shutting off the engine affects it in any way then your clutch would have to be not fully disengaging when you put the pedal in. Check to see whether your clutch is operating properly.
Yup, I had the SAME issue with my Prelude. It turned out to be a bad clutch. The disk was warped and one of the disk springs fell out.
