Important radiator fan question. Please help.
redsx13
Car: 93 240sx 03 350z
Hi, I recentily bought a flex-a-lite duel electric fan to replace my mechanical one on an sr20. Anyway, They sent me a "pusher" which is supposed to be mounted on the front of the radiator between the radiator and the intercooler, is this correct?Is there enough clearence? wouldnt i want a "puller"fan for the back of the radiator between the radiator and the motor?any advice is appraciated.
thanks
r3v_v3ng3
Car: 91 fastback ka-t
is there any way you can make it to a puller? cause i know some fans that if you wire it backwards it will spin the opposite way. i think puller is what you want because if you put a pusher it will just get more in the way since you already have an intercooler.
