trpower7 »
https://forums.nicoclub.com/trpower7-u205.html
Tue Jun 03, 2003 3:41 pm
Wow, umm, first, your english is horrible.
Sup = Hello, or even whats up is acceptableFuked = we have the word filter for a reasonCuz = because
Now, to answer your question, the head gasket is not a very likely culprit. But we need alot more information. Smoking, oil in water, water in the oil, stuttering, driveability symptoms, etc. A badly leaking head gasket could allow enough water into the cylinders to cause it to shut down, but the way you describe it it's not likely. It would cause stuttering, hesitation, misfire, etc, not just shutting off immediately. If you have a turbo KA, as your signature said, you should be able to diagnose this kind of thing on your own. If you don't, it's rather poserish. Please provide more information.
