SmithSR »
https://forums.nicoclub.com/smithsr-u5241.html
Fri May 09, 2003 1:39 pm
AND, at the time that you do replace said tie rod ends, you should take your car to have a proper 4 wheel alignment. If your tie rod ends are loose to this point, an alignment is always a good idea. A pre-alignment inspection could uncover some other loose/worn steering/suspension components. Just be sure to find a good shop that is trustworthy and won't rip you off. Good luck!
