Important links in FAQ are broken.
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
The following links in the SR FAQ are broken.
Heavy Throttle's SR Swap FAQ
FRSport's Wiring FAQ
SpeedRacer1's Vacuum Line Diagram
Alternative Ignitor Chips FAQ
The fact that heavy throttle's sr swap faq is gone, along with frsport's wiring faq, is pretty crappy.
PyR0NiAk
Did noone see this?
zachattack_5491
Car: Pignose S13 Redtop SR
Sorry this is a little old. FRSport wiring was only moved. it's here: http://www.frsport.com/SR20DET....html
Hijacker
Car: '92 240sx Convertible
'94 F-150
Heavy Throttle's is down, I had it linked to a webarchive link, but that seems to change with the wind for some reason.
As for Speed Racer's vac diagram, either his photobucket account is gone or something. I don't have a backup copy of it, but I do have the picture of the one from the JDM service manual posted. It'll have to suffice.
Thanks for the updated link, Zach
Totally off topic, but are you from Portsmouth, Chris? I'm from Wheelersburg originally.
