swwifty wrote:I just wanted to add my .2 cents. I think one of the best ways to reduce heat in the engine bay is to ceramic coat the turbo, turbo manifold, and the downpipe. I've had first had experience with before and after cermanic coatings on headers, and it makes a huge difference!
Also to note, Mark had a upgraded radiator and even a oil cooler and still toasted a rod. It's something to think about....
Yup, I had a 2.1" all aluminum Koyo radiator, brand new water pump, thermostat, brand new oil pump (I was REALLY close to getting a hi-flow aftermarkete oil pump), fairly large front mount oil cooler...my water temps never went past 178 degrees, this entire summer (75% water, 25% anti-freeze, a bottle of redline water wetter). I also have a heat shield for the turbo and the manifold/downpipe are ceramic coated (not a very good coating, but it is ceramic nonetheless).
When the engine blew I had only been out on a 10 minute ride and only hit boost once before then. Water temp was 178, ambient air was fairly hot and humid.
The engine was by no means too hot.
But it is uncanny how the #3 rod was destroyed in all the cases of rod-failure...I haven't had a chance to tear the engine down or inspect anything yet...a friend just towed it back this evening. Not sure if I'll even have time to tear into it before I leave for school...pulling the engine/transmission is a pretty involved process!
Another point of interest is that all of the engines throwing rods have happened at high boost levels. No one has thrown a rod at low boost levels (say, 8-11 psi). If the reason the rods were failing were due to an oil lubrication problem, wouldn't they also fail at the same rate at 8-11 psi as well?
But thumbs up for the thread!
