important for new nissan owners
s13sr20chris
03 altima radiator leakscause: radiator capfix: replace radiator cap, then radiator if neccesaryif you just replace the radiator it will go bad again due to 60psi or so of water pressure
02 and up altima poor heater performancecause: wrong coolant mixfix: used EXACTLY 50/50 mixa 55% coolant to 45% water mix will drop heater output by approx 15 degrees
titan/armada brake pulsationcause: caliper slides bindingfix: relube or replace caliper slidesif turning/replacing rotors, you must replace the caliper bracket bolts. they are one time use only bolts.
