Carl H »
https://forums.nicoclub.com/carl-h-u9196.html
Wed Dec 29, 2004 1:11 pm
on my engine as it sits now i have a good ridge banjo with a 12mm hole and -4an fitting.it then goes to a -4 pushfit hose then to the turbo using a -4an to 7/16" inverted flare adaptor.you still will need to enlarge the stock banjo bolt if you are running a bush turbo unless you can find a 25mm long 12mm banjo with a 1.25 pitch on it.
