immobilizer activated infiniti qx4 - 1999
Victor1973
Car: 1999 Infiniti QX4
By mistake I left the lights on for 24 hours, of my Infiniti QX4, the battery was discharged, I tried several times to help the battery with another battery, but when I connected the terminals (-+) an alarm was immediately activated and when I pass the switch ignition engine won't start...i didn't know the car had an alarm or immobilizer when i bought it.. Can someone help me?..i need to eliminate the problem and start the engine.
Reason: Moved to correct Forum
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
The alarm is reset by using the hard key to unlock the cylinder on the driver's door.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Just a friendly note.
Cross-posting (i.e. posting the same message in more than one forum board) is frowned upon. It's confusing and often counterproductive. Please choose the forum topic that is closest to your post, and place it there only. If you should create a post in one forum, and later realize it would be more appropriate in another forum, please delete the original before posting it again.
Your duplicate posts in the other forums have been deleted.
