ZGadson »
https://forums.nicoclub.com/zgadson-u56225.html
Wed Aug 08, 2007 1:46 pm
I bought my car used and from the start I noticed that the transmission slipped on occasion when taking off at a moderate pace. It would slip between 1st and 2nd gear.
Today I was taking off slightly faster than usual when I felt a jolt as if someone rear-ended me but there was no one behind me. The car (even with the gas pedal to the floor) started slowing down until a crawl. It still moves when you give it gas (going forward and when in reverse) but I can't go much faster than idle speed.
When I felt the jolt, the AT check light came on steady, the CEL light came on, and the traction light came on, just about everything.
The car is still under warranty (drivetrain only) so Im wondering if I should cough up the dough for a tow truck to take it all the way to an Infiniti dealer (which is an hour away from me) in hopes that it is the transmission that needs repair).
I was told by my mechanic friend that a "clutch pack"was bad. Could this be what happend to my car? Clutch pack go out?
