SullivanRacing06 wrote:
agreed, let your car idle, and pull each injector clip one at a time, see if the idle changes every time u pull one off, obv reattach the clip after u pull it off, do all 6 and if the idle changes every time then its not a injector, and pull the vac line off the fpr and reset your fuel pressure,
Agreed. But if the injector is leaking fuel past the o-ring, pulling the connectors off won't change the idle much on the bad cylinders. Might actually help smooth it out if anything.
How do you know it is rich? What do your plugs look like after idling for a minute or two? Are they wet? Does it smell like gas?
A ROM tune isn't going to do anything for you until you fix the problem, so let's not get ahead of ourselves.
