im tired of chasing please help!
Discuss topics related to the VG and VE series engines.
87pathfinder
Car: 1987 nissan pathfinder 3.0 lt 4x4
my 87 pathfinder 4x4 3.0 automatic wont go over 2800 rpms. i was told to change distributors and i have i tryed 2 different ones and no change. i changed the cap rotor wires and coil. i just put a new fuel pump and filter in about a month ago and i dont know what else to do, somebody please help!
float_6969
That sounds like a bad MAFS to me. Is the CEL on?
87pathfinder
my truck doesnt have a mafs sensor. or map sensor and doesnt have a check eng light equipped
float_6969
Sorry, I glanced at it and I thought it said 97! Have you checked the actual ignition timing on the crank with a timing light?
87pathfinder
yes timing is dead on. if the fuel pump was bad would that cause it? ive had a few people say that i might have got a bad pump
front-range-tuner
Car: 1986.5 Nissan Hardbody truck
Did you read the codes off the computer itself? I found a FSM that informed me that the engine light on the dash does not give all the codes. The computer itself has a red and green pair of LEDs located on the back of it that flash codes to the viewer as well as utilizing the engine light on the dash. It should be located under the pass seat.
You have the same engine I do, and it is strong but has primitive sensors. That particular block has a "mixer heater" that sits beneath the TBI injection system. This "mixer heater" is the predecessor to a MAFS. It sounds like it tripped the computer and it is running in some sort of safe mode.
87pathfinder
how do i reset the computer?
front-range-tuner
A Chilton's manual or Haynes will tell you exactly how. You can usually get em at any auto-parts stores, or check them out from your local library sometimes too if you don't want to buy one. I personally don't know the exact process for your Pathy. U might want to read the codes before resetting them too once you have the manual. The codes will tell you if something is wrong. I would start with that.
Return to “VG30 / VE30 Forum”
