im swapping an sr20 from a g20 into my b13 1991
unioncarter
Car: 91 B13 XE SWAPPING TO SR20
will the ecu and engine harness work from the g20 on my b13.any help will be greatly appreciated.also the infinity is an automatic will it matterif the infinity g20 is the same year as my car will the harness and ecu work then PLEASE HELP ME
Modified by unioncarter at 9:52 AM 6/22/2006
Modified by unioncarter at 11:52 AM 6/23/2006
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Depending on what year G20 determines if the ECU will work.
still4punk
Car: 1997 200sx SE-R
i dont think an automatic g20 ecu will work on a manual sentra, will it?
RED_DET
Vendor
2011 Infiniti G37x
It's feasible, but if the g20 is obdII, then it won't work no matter what.
Big-Lettuce
Car: Jesus Christ, my family, & recreational time.
Yo look a motor is a motor, if the sr20de is from a '91 DUB going into a '91 S-Class (SE-R for dummies if I had to break down S-Class) then this will drop right in. Like the guys stated earlier. . . Questions. . . . If you have a '91 S-Class your car has an ECU use your 5spd ECU. No the auto program from the DUB ECU will not work on your stick S-Class. If it is a OBD2 motor (which I know it is not because you said it is same year as your S-Class) OBD2 ENGINE will still work, NOT ECU however you'll have extra stuff going on with the motor and you'll need to get the OBD1 parts and retro-fit. Stupid question having a DUB & NX2K I cannot recall what the NX2K is? I know the DUB is high port, never owned a S-Class B13? Hit us back hoss!
