gani »
https://forums.nicoclub.com/gani-u8441.html
Sun Aug 29, 2004 6:13 am
well ive got this weird problem with my ca where when its cold the engine seems to misfire and hesitate alot just when it gets into boost. after it hits normal operating temperature it clears it self and runs with no hesitation or with very slight hesitation. ive tried new coil packs, new engine temp sensor,check for continuity on the knock sensor wire, maf wires ,tps wires. checked all grounds and added more grounds. the only thing i havent changed yet is the knock sensor but i doubt its the problem since this only happens when the engine temp is cold. i have also tried new spark plugs and that doesnt help. im running 10psi of boost off a ca t25 modified with a sr t25 compressor housing with stock intercooler
