im stuck dont know what else ....shifting issues
General discussion area for the L31-chassis Altima, including the 05-06 SE-R models.
jayPrick91
Car: 02 altima se 5speed
So i have a 02 altima se 5speed i have a issue with shifting..at first it sucked untill i changed the slave and master cylinder then it got better but its still there clutch is also good and i have bled it tons of times
So going from 1st to 2nd sucks sometimes and going into reverse also blows..if i try to step on it hard at a stop sign i will grind going into second. So what it feels like to me is a bad master cylinder but it has a brand new one anyone have this issue?
What seems to get around the shifting is if i press on the clutch hard and shift hard but it gets annoying every other car ive owned never shifted like this
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Clutch pedal adjustment?
jayPrick91
Didnt even know someone wrote back but i dont know how to adjust it ...i have it the way the last master was ...i mean i do have to step on the clutch to the floor so i can put the car into gear .everything os fine on it other then its sometimes hard to get into gear and the whole second gear thing
Nm-Ser
Car: 2006 Nissan Altima SE-R 6mt
Maybe needs new transmission fluid? I put amsoil gl-4 and it helps smooth it out.
Return to “3rd Generation Altima Sedan (2002-2006)”
