Bumnah »
https://forums.nicoclub.com/bumnah-u39849.html
Thu Nov 05, 2009 3:13 am
Check ball jointsCheck wheel bearings, starting with the front wheels.Check bushings in the lower control arms, if your tension rods have rubber bushings still, check those too.
It was hard to understand everything you were saying, but it looks like you had some missing OEM hardware, and replaced it with other stuff.
All the nuts on the suspension are deformed thread nut, they are designed to take much more abuse than your standard hardware. It is a very good idea to only use OEM hardware. Standard hardware shouldn't just come loose immediately, but over time it's very likely they will.
Make sure you're torquing everything properly as well.
If you are reinstalling suspension pieces with the factory rubber still installed, all suspension pieces need to be torqued down with the suspension under load, you will get binding if you don't.
