im screwd
Mudvayne
Car: 91 Nissan 240SX
93 Nissan 300ZX
81 Chevy El Camino 496 stroker
i broke a screw in the head for the cam and striped one. i put the engine in top dead center and the cams were facing in, was that right. i see so many pictures and they give me different wase. dose someone have a picture that shows me the right way
Nastjuid
Car: S13 KA24DE
edit: wait what, you broke the bolt that attaches the cam sprocket to the cam?
well, you want TDC on compression stroke. What do the timing marks look like? If you turn that crank so the cams are pointing out, where is that #1 piston?
this is tdc compression stroke:http://www.nicoclub.com/articl...2.jpg
This is what those cams will look like when you're tdc compression stroke:http://www.nicoclub.com/articl...4.jpg
Mudvayne
93 Nissan 300ZX
i broke one in the head. and striped one of the holes. the 10mm bolt that hold the cam down
Nastjuid
Car: S13 KA24DE
Ahhh, that's not horribly bad. A machine shop might be able to get it out. they may even be nice enough guys to helicoil or use other means to fix the stripped one. Call around, one of them will at least stear you in the right direction.
slipperypanda09
Car: 90 Nissan 240sx se, 91 Nissan 240sx le, 99 Subaru Impreza 2.5rs, 88 Toyota Supra Turbo
that sucks dude... but dont give up. nothing unfixable. if machine shops tell you they cant do it, its probly cause they dont want to do it. good luck.
Mudvayne
93 Nissan 300ZX
i got the broken one out but need to fix the striped one. theres no machine shop where i live. what size retap do i need for the striped one. my auto parts stores where i live suck. going to have to go out of town to get one.
