im sad. :( No oil from turbo feed
grenade180sx
Car: 180sx
so as the title states. i just installed my rb25 i purchased the short block from JDM of miam,i put on all my IM and EM etc odds and ends but when i go to crank the motor not even a single drop of oil comes outta the hole for the feed, all ive had lately is headaches the line is a -4 but when i put the whole line off the block and leave it open theres nothing. im fearing the oil pump is done. i contacted jdm of miami and spoke to carlos he couldnt help me much as he isnt a mechanic theres nothing blocking the feed inside the hole. time to hook up a oil pressure gauge and see if i get any oil pressure at all.
please help
thanksRiley
Modified by grenade180sx at 10:00 AM 2/5/2009
240z4u
Car: '95 Nissan 240SX
Your going to have to do a TON of cranking to get that pump primed. Do you have oil to the top end? What your dealing with does not sound too uncommon especially since I am sure your oil filter is empty.
Evan
grenade180sx
Car: 180sx
like its retarded i have oil filter relocation kit as well with 6 quarts so i figure oil should be there sometime damn it haha
thank you tho ill keep at it, i usual cracnk for 5 sec or so every time i crank.. should i go longer? worse case scenario the oil pump is shot i dotn wanna screw anything else up ya feel me
whats the easist way to check if top end has oil pull off the return on the side of the block?
Largekid
Car: '96 RB S14 SE, '04 LS6 CTS-V
I would crank for 10sec a few diff times and see if you have anything coming out. As far as checking for oil up top, just pull your valve cover off and see if there is oil present. Like said before, dont look for the worst...this is a common occurance
grenade180sx
Car: 180sx
i pulled the valve covers it looks pretty dry a lite oil film on the cam ahh man if its not one thing its another.
BoostFab
Car: S13cp, S13fb, S14z
you are going to have to keep cranking, unbolt one end of the remote oil filter let it prime. you have to know it takes more cranking time to fill up all the stuff you have added. cranking oil flow is different then when the motor is running.
grenade180sx
Car: 180sx
the motor has been turned over atleast 20 times. for ten second intervals. all that oil has to go somewhere ;p;
240z4u
You have an external oil cooler? It takes a while to get that oil moving around. Especially with a system that is larger capacity.
You DID put your oil pickup tube on right?
Keep at it.
Evan
grenade180sx
Car: 180sx
240z4u wrote:You have an external oil cooler? It takes a while to get that oil moving around. Especially with a system that is larger capacity.
Keep at it.
Evan
never pulled the pan off, i pulled off the oil relo line and cranked nothing coming out it has to be that damn oil pump!
240z4u
Was there something wrong with the motor that leads you to think that the pump is bad? IE it was seized up or something? I will almost bet money the pump is fine.
Evan
johnzm
stop all this just start the motor man. it wont hurt it to let it run for 20 seconds without oil pressure as long as your not driving it around. i dont think u will get pressure in a system that big any other way....
and as others have said i seriously doubt the pump is bad.
Carl H
pulling the plugs from the engine will help build pressure quicker.it took about 5-10 good 15 sec burst cranks for my rb20 to prime the system.
Shocker
Car: 89 240sxHB rb26/30
Carl H wrote:pulling the plugs from the engine will help build pressure quicker.it took about 5-10 good 15 sec burst cranks for my rb20 to prime the system.
Definitely pull the plugs.
Be VERY careful to not overheat your starter doing this. I burnt out one doing this.
Anymore I don't bother priming, our engines are not old school v8's, ours build pressure immediately after firing. If you have enough assembly lube on all your parts there is no worry about hurting your bearings.
If it doesnt build pressure a few seconds after start up shut it down, check over your OIL pressure connections/wiring and go from there.
grenade180sx
Car: 180sx
is there any risk of damaging the crankshaft bearing etc with the cranking? even if the oil pump is bad?
