im rebuilding and new specs
boom
Car: sil80
im new to the rb life, i don't know much about the rb other then it's awesome. righ now im rebuilding an rb20det. im building it to do some drifting with, so im building it to take ALOT of abuse. right now im taking a engine rebuild class at school, so right now i need sources for everything rb20, like valve stem and valve guide specs(like how thick or tin they can be so it's in spec). i need every little detail about the inturnals as possible. and hopefully when im done i'll have a bamf motor! any little tid bit will help.
Fearsome_tea
What makes it awsome?
nosanhere
Fearsome_tea wrote:What makes it awsome?
Hahaha Sorry but that amused me. I have a file somewhere, or atleast I should, that shows about every measurement and bit of info on the rb engines. I'll get to trying to find it
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
1. Search for the FSM before anything else. You'll get your specs and tolorances and such there.
2. Valve stem seals as well as all the misc. gaskets can be found with a engine gasket set which is sold all over.
3. Pistons can be bought pretty much anywhere as well, either it be wisco, cp, or japanese brands tomei, etc.
4. Finding upgraded Rods for your motor is going to be a hard item to source. So good luck there.
5. Bearings can be found through NICO sponsors (IIRC Phase2 might have them). Or ACL, King, Nissan, etc.
5. Headgasket, anywhere that sells cometic. You can also look at the over sea retailers that sell Tomei, HKS, etc. gaskets as well.
6. Valvetrain, Tomei is the first place many people look. Including Cams.
7. Hardware, ARP.
Our sponsors are a very good source to start at, as well as our SEARCH.
Good luck
boom
Car: sil80
where can i find that FSM, or can you direct me to the thread that has it
Eikon
Car: 71 240z, 93 Supra TT
familiarize yourself with the search function on this forum.
Click search.. type in Rb20det fsm. You'll get a thread that gives you the link to nicoclub's hosted RB fsm's.
I'll save you the work this time - http://www.nicoclub.com/FSM/rb/
But in the future.. try to search for stuff first, then if you can't find it.. go ahead and ask. We're a helpful bunch, and we like to take care of our own, but it gets old pointing people to the same old info over and over when they could find it themselves if they try.
Anyhow... welcome to the forum. Glad to have you aboard!
