Im rebuilding a sohc valve head any ideas?
OG-240
Car: 1990 240sx
I have a 90" 240 I just had work done to the engine; the machanic said that the bottom end seems like new, but it needs valve job. Like most men, I want to go-all-out and throw in some preformance valves/cam to improve HP. The only problem is I don't knew who makes preformance parts for the ka24e(sohc). I would greatly apresiate references or advise thank you.
pregmantis
I wouldnt recomend any upgrades until you upgrade your induction and exhaust. After the intake and exh, I would go with a cam then adjstable rockers, and any fuel mods to complement the upgrades. nismo sells stuff like that. btw, valve-piston clearance may be an issue with a new cam, sorry I cant tell you the max lift/durat you can run w/out notching anything. oh...porting.
SMoKeM240
Car: 89 240sx NA/KA
if u get a cam, most likey u will have to get adjustable rockers. u can have them do a 3angle valve grind helps a lil bit
Bigvinnie
Car: 2004 Nissan Frontier desert Runner, 2014 Nissan Titan
Port the intake side, and the exhaust bring it up to par with the DE heads, which have significantly larger ports.
nelson8708
Car: 1989 Nissan 240sx Fastback
1994 Acura Integra LS
you could go to hybridka.com........they sell sohc cams and a new solid lifter conversion.
OG-240
Car: 1990 240sx
Thanks man good idea, got any other websites or sources
