pgt892 wrote:Like was said before, you can cut the yellow/green wire (pin 32) going to your ECU. The VSS sends the signal to the cluster, then to the ECU. So your speedo will still work, assuming it already does, but the ECU will not know how fast you are going. Worked for me without any issues.
tagstarr wrote:thank you
WTF? Why would spend money on a mod that requires only cutting 1 wire?wildacexxx wrote:go on ebay and get a speed limit cutter.
