im new need some help here, thank you
dplxy
i just swap in a 13 blacktop, after that i put in bov, intake,catbak...what sould i do next?i was thinking abt koyo radiator and FAL fan..what do u guys think??any other suggest?no power mod for now, i will do it later, because summer is heresocal is too hot.... i also wanna know if i do get the radiator,will a twin line 320 fan fit right in?
dplxy
up..
AznRide
Car: Cars, hondas, import cars, girls, cars, girls, girls, and more beautiful girls.
you need walbro 255 fuel pump, z32 fuel filter, turbo outlet pipe, 3" test pipe, then get rid of your fan, get electric ones, they all the same so if they work, you're fine. Boost controller, safcII if you want an affordable tunning device before getting a SAES. After that, get new injectors if you want a bigger turbo or want to run safe at 17psi...for now, i think it should be enough for you. Also, get a clutch if you haven't got one.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
rocker arm stoppers.
dplxy
AznRide wrote:you need walbro 255 fuel pump, z32 fuel filter, turbo outlet pipe, 3" test pipe, then get rid of your fan, get electric ones, they all the same so if they work, you're fine. Boost controller, safcII if you want an affordable tunning device before getting a SAES. After that, get new injectors if you want a bigger turbo or want to run safe at 17psi...for now, i think it should be enough for you. Also, get a clutch if you haven't got one.
since summer is here in socal so i will do radiator and fan is firstSuspensions~~ some tein coilover with upper mount after that i will do some bigbreak upgradethen i will get some twin disc clutch then a dp and high flow cat, since is cheap and it will make ur turbo bootsbit faster and it does make some powerthen i will move on to the power modsfuel injectors fuel pumpfuel filterMAF fmicIntake manifoldexhaust manifoldturbo: GT28RS then the last thing is eculong way to go
S13240
I say get the koyo radiator with whatever e-fans you want and get your ac working if it's not already since you did say "summer is here" :icesangel
dplxy
S13240 wrote:I say get the koyo radiator with whatever e-fans you want and get your ac working if it's not already since you did say "summer is here" :icesangel
i know, i will get the koyo and fal fan, the 1st thing is go to pepboys tomorrow and charge my AC......but the thing is they will make me pay 24.99 to chack it and 168 to charge it...omg......r there some cheaper place that i can go? or spend 200 for recharge AC is fair price...:help :help :help
