Im new here so help!!!!!
1972-1979 Datsun 620 forums. All 620-specific topics and discussion can be found here.
lynx77
I just got a 77 620 about a month ago ,last week I got hit by a truck and totaled it but the damage is only on the pasnger front so is it worth it to repair or should I just buy a new truck:( .thanks
mklotz70
Really no way for us to make that call without pics of the damage or any idea of your abilities.  If it's only sheet metal and not frame damage, parts should be easy enough to find.  If you can do the work yourself, it should be worth it to keep it.
phlebmaster
Car: 1973 240z L26 4spd rip roar and ready to go!
Welcome to the forum...sorry to hear about your 620.
Ditto to what Mike said....pics?? :dude:
lynx77
Ill try to get pics up soon ,thanks for the advice
[img]file:///C:/Users/Shaunda/Pictures/2008-06-25%2077%20Datsun%20620/77%20Datsun%20620%20001.JPG[/img][img]file:///C:/Users/Shaunda/Pictures/2008-06-25%2077%20Datsun%20620/77%20Datsun%20620%20001.JPG[/img]
lynx77
heres more pics
lynx77
Its bad I know
phlebmaster
Ouch!!
I would question the integrity if the frame and the driveability.
Did you get hurt??
lynx77
whiplash and bruises ,but the frame and suspention are amazingly untouched
phlebmaster
Wow!! :dude:
If thats the case....parts a fairly common. Rebuild her I say.
Keep us updated
lynx77
will do thanks for the advise:cool:
mklotz70
Looks like the hit was high enough to spare the suspension.  You won't know for sure on the frame until the bad sheet metal is out of the way.
Welding a new front end on will be a ton of work and the sheet metal damage pushed back all the way to the firewall.  If you have to do any work to the firewall, I'll try to find another cab to work with.  Since you know all the good stuff on your rig, I'd consider buying another 620 that's fairly staight, but mechanically bad and swap all your good stuff to it.
Unless you have the tools/abilities to cut/weld the entire front end back on, you need another rig.  That isn't anything that you can pull out with a comealong.
By the time you buy all the little parts at the s/y, you could probably find another 620 for about the same.  With scrap metal being up around $220/ton, you'll make some money back on the left over pieces......they're worth the same even if they're crunched :)
Return to “Datsun 620”
