im new and have a question!
lazymofo
hi all! i got a S13 with a red top... i've got my swap for awhile now... and a problem just popped up for the past weeks! my tail light fuse keep burning!! by now i've proabably burned about 100+ fuses! i just replaced the alternator... has this happened to anyone!?!? if so help is apperciated
SET240SX
Car: fast rides
I doubt the sr swap has anything to do with blowing the taillight fuse or you would see other problems as well. Good luck on finding that 1. Check the fsm and see what all could cause the fuse to blow and start eliminating things.
getnrowdy23
Car: '95 sr20det 240sx se/2004 suzuki sv650s
try getting one size larger fuse.
Movingviolation240
Car: '95 Nissan 240SX 400hp SR20DET -SOLD
'93 Lexus SC300 w/ SP66 turbo kit
I had that same problem, turnned out to be a short in one of the front side marker lights that I had.
That might give you a clue as to what you need start looking at.
Paul
creophus
Car: 240SX SE & 200SX
Paul,
I probably asked you this before, but what wheels are you running on that S14? Can you/Cardinal sell me a set?
sactos13
Car: 92 Nissan 240sx
Check the bulbs in the fsm and taillights and make sure they are correct. You might also look at the fsm and find the ground location for the harness and check it's secure/clean.
Checking for shorts is also a good idea.
blackbeltclub99
Car: 93 RX7
did you just put in a new radio? I had this problem after installing a new radio. I had it grounded wrong. Hope this helps. Also if you have not put in a new radio, have you installed and new elextronics?
Movingviolation240
They are Volk GT-C's, I actually got them through Enjukuracing. I'd hit them up http://www.enjukuracing.com I'm not 100% sure of the offset, it was 18x9 up front and 18x10 in the back. I wanna guess and say offset was 38 and 42 but don't quote me on that. I sold the wheels with the car about 2 months ago.
Paul
creophus
Thanks for the reply on that Paul!
