Chaluska »
https://forums.nicoclub.com/chaluska-u25522.html
Mon Jun 08, 2009 10:16 am
If your doing it ALL by yourself.
Stock block KA-T (3000)
10psi stock block KA, T3/T4 will net you anywhere between 260-280 WHP depending on the condition of your engine This is assuming you purchase 550cc or larger injectors, and a pretuned ECU, Z32 MAF, but the engine remains stock...
Stock SR20det (2100 + boltons)
Assuming your getting a fuel pump, FMIC, exhaust, 3" downpipe. on the same PSI, you will be lucky to break 230whp
Stock Block RB. (no clue on pricing)
Obviously the most powerful engine nissan makes, But obviously the most powerful against your wallet as well.. May be cheaper to swap in a LS1, or 1JZ.
