im having troubles with camber
MikeySand
Car: nissan 240sx
ok so after putting a poly bushing kit. coilovers and all the suspension arms in the rear i sent my car to get aligned after setting the ride height i wanted. the car came back with positive camber in the front to the tune of 0.8 on both sides. now the rear is perfectly okrunning about 2 degrees negative. i popped the hood to check the camber plates and they are set to negative. mind you all the installation was done by my father who is a certified bmw mechanic. now what he says is that ive set the car so low that due to geometry of the suspension it started to push the wheels positive instead of negative, now i dont know if this is correct. his solution is to buy front control arms so that i can adjust my camber further. is this the only solution i have? what could this problem be due to? thank you for your time and input
MikeySand
Car: nissan 240sx
forgot to add1996 240sxwork emotion xd9 18x9 +20 in front 18x10 +17 in backrolled fenders
r3v_v3ng3
Car: 91 fastback ka-t
if you have coilovers, most of them should be slotted at the bolt holes to the knuckle. just loosen it and push or pull it in more and retighten. then realign it. if not make a slot on your strut where it mates to the knuckle
MikeySand
Car: nissan 240sx
well the coilovers dont have slotted holes where they bolt up the the knuckle. oh and they are made by D2.
esahuque
Car: 95 240sx KA-T, 04 frontier
I have the same problem, did you ever figure it out?
moulton712
Car: coupe, hatch, both s13s
sometimes you steering rack can be pushed over. this is the case of my track car. also some suspension parts can be warped. like my friend drifted one of my stock 240s one night and hit a curb. the car drove straight untill i put coilovers, camberplates, new tierods, etc.. after doing this i noticed the camber was way off.
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
i believe i read somewhere there was a fix for this problem with a certain tie rod...as a matter of fact..i think it was an article in D-sport..or Project car magazine...i save all my issues and ill look for the article and give the info i find..may take some time thou...if i remeber corectly..the tie rod had an adjusted (raised) mounting serface that corected the issue...give me a few days to find the info.
r3v_v3ng3
don't sound right cause tie rods are for toe's
