detser122 wrote:can you explain in laymens terms? Im sorry if its too much to ask man, thanx...Oh! is it the thermostat? I dont know what im asking but please help, im hopefully fixing it this weekend.
I'll translate for him and tell you more about the condition.
The Clutch Master Cylinder is on the fire wall at the opposite end of the rod comming off of the clutch pedal. The seal where the rod goes into the master cylinder can go out, causing it to leak into the car. If the fluid goes too low in the cylinder, (ie, dry) then you will have no clutch pedal untill you fill and bleed the system. The only way to fix the leak is to replace the Master cylinder unfortunately.
As for the Coolant Temp Sensor........when it goes bad the car will go into a safety mode that makes the car assume a certain temperature (near fully warmed up) which will cause the car to run extremely rich untill it is warmed up and run imperfect/down on power once it's up to temp. If you have an S13 with a DOHC you can only get a new sensor from the dealer for $40. Autozone, Napa, etc don't carry it. (The show the wrong part #)
I would certainly check the codes however as this agian could just be your severe need for a tune up. Check the faq for info on how to check your codes. If you CTS is bad it'll show up in your ecu.
