im havign a big problem.............
white 240
Car: 1991 nissan 240 sx
hey guys im new in this club but i been having problems with my s13.. im putting a 98 ka24 in to my 91 but it seems that a lot of stuff and wires are not same.. so i would appreciated that somebody that have done it and knows about it would help me. thanks
180fan
Car: 89 fastback
take the wiring and manifolds from the 91 and use it on the 98 head/block.
bone_stock_240
Car: 1995 Infiniti Q45
Also use the s13 distributor on the s14 engine. I changed the alternator as well, but I don't know if that was actually necessary.
Edit: Actually, I am not too sure about the distributor, since the engine I swapped in was a 95, so it still had the 2 row timing chain. Didn't the 98 only have a single row? I am not sure how this will effect the fitment of the distributor. I am sure someone more knowledgeable than I will chime in.
white 240
already did all that i change the alternator power steering pump and the distributor......but there is 2 plugs from the intake manifold that the s13 has it but the s14 don't. those plugs goes by the fire wall but the s14 seems that it doesn't need them but i wanna make sure if im doing everything correct.........................
LayNLow240
Car: 92 240 coupe
The S14 intake manifold doesnt have swirl control valves that the S13 does, so thats one. The other... I am not sure about. Is the S14 engine from an automatic? If so then the extra plug is from the TPS, auto and manual TPS are different and the auto has an extra plug.Edit:If you want to get rid of the SCV's for a few extra hp, then use the S14 upper intake manifold and S13 lower manifold. Then just remove the SCV selenoid and put some vac line connecting the 2 lines it opened up.
Modified by LayNLow240 at 6:32 PM 8/28/2007
white 240
yeah thats what im about to do cause try to do everything and i think that is the last thing to be done but if i find any other thing i will let u know..thanks u guys u, been really helpful...........
white 240
ok guys im having a new problem now, my firing order was wrong so i put it 1-3-4-2, that is the way that it goes, but the car wont start. do you think that is the timing? because im using the s13 distributor on the s14 engine, and it also is doing back fire. so i dont know what else to do, pls somebody has to know.......
white 240
come on people i need some help... somebody............
180fan
Car: 89 fastback
reset the timing on the motor to be 100%. I have a feeling though you've got the distributor a bit off eh?
white 240
how can i reset it? ..............
