cuffuup28 »
https://forums.nicoclub.com/cuffuup28-u62328.html
Sun Apr 06, 2008 1:55 pm
1. Turn your car key to the ON position and press and hold the button to move your window all the way down and when it reaches the bottom hold for 2-3 seconds. Then press up and hold it as it goes up and then when it seals hold it for 5-6 seconds.
If that does not work:
2. Remove your door trim panel and where the motor is located there should be a small rubber nipple/button poking out. Roll your window all the way down and hold the button for 3-5 secs. Then roll your window all the way up and while holding the Window up button press and hold the nipple/button for 3-5 seconds.
Hopefully this works becasuse both these techniques have worked when I have fixed Altimas, Maximas, 350Z'z, Versa's and Sentra's and Murano's
