Im going to napa tommoro - what length are the stock lugs
Kalypso
I broke a lug from over tighteningand the others look frail from oxidizing.
I have the ichiba five lug - front and back - and I believe my lug sizes are
12mm x 1.25
what Length are the stock lugs?
Kalypso
Kalypso
the ichiba five lug conversion uses studs that are
46mm long12mm wide the tread is 1.25
they are from all year 350z front studs.
remove the brake caliper, pop off the rotor, remove the pin, take of the hub. hammer out the old studs and do the same process in reverse.
