Well, the 96 odbii one won't do anyone any good. And I think some of the later 94s and 95s had a different ecu as well. CA emissions cars are only a little different having the extra sensor for emissions.
I should have taken a pic of my ecu when I had it out of the car with the big number on it. I think it said 23. One from twinturbo.net has a 26 on it.
They should all be type "N-7" whatever that means.
I know that the HKS ALC for auto transmission z32 is the same exact one sold outside the states for rb20det (not r31!) automatics.
It looks like rb26dett uses the same ecu (n-7 type) as well. While the rb25det can use either a n-7 or a n-28 depending on model year..
http://www.nippon-seiki.co.jp/....htmlh ... p/....html
If you look on page 1, most sr20det use n-9, while 1 model s14 uses a n-7, and s13s use n-11 in the turbo model.
I find it funny that the CA18DE and DET from an s13 use n-7.
It would be interesting to use a romulator and run several different engines with one ecu just to see if it can be done.
I may buy an extra z32 ecu from ebay just to try it if I can get an rb20det for the wife's 98 240sx.
Long post, is everyone confused enough now?
