Im back!
Sideways s12
Car: 84 turbo s12
Ok so it would be better to just get the harness from wiring specialties and wire in the s12 sensors?
Sideways s12
Car: 84 turbo s12
I did move the harness and ecu at the same time when this happened. I don't know if that helps any. The harness looks intact from what I can see and it's all wrapped nicely. but moving it shouldn't have caused it to not start so I'm lost on that. it could be something minor or it could be something major. I just don't know much about wiring and don't want to f*** it up...
float_6969
It shouldn't matter. Like, you should be able to shake the ecu while the car is running and it shouldn't have any effect on how the engine runs. There's either a harness issue, or an ECU issue.
Sideways s12
Car: 84 turbo s12
I'm pretty positive it's a harness issue... Like I said I had to move the harness and ecu to see get to the top of the ecu. More specifically I had to move the harness in order to move the ecu... I just need to know if I should gret the wiring specialties harness and go fro there...
float_6969
I would. Hell, if I build another car at some point, I have every intention of buying a WS harness and then modifying it to suit my needs.
Sideways s12
Car: 84 turbo s12
yeah That's what I'm going to do then... I hate having wiring issues t's usually what keeps me from driving my car. I had the same issue with the one in my sig but atleast the P.O. of my current car attempted to do right... I'm just not sure where he went wrong.and really don't have the time patience or know how to pull the harness and dig through it... For the stuff I can't do I take it to a shop but the shop I use the owner is only there on Sundays because he's taking a break from building cars...
Sideways s12
Car: 84 turbo s12
Just an update she still sits waiting to get wiring done....
float_6969
Damn...
Sideways s12
Car: 84 turbo s12
Turns out I need an ecu t370 resistor blew in the ecu...
float_6969
Hmm, WHY did it blow? Resistors don't usually fail for no reason. You need to make 100% sure your wiring is spot on. If it's not, you'll just toast the next ECU you plug into it.
Sideways s12
Car: 84 turbo s12
Yeah thats what we're trying to figure out.....I said the samething I dont want to buy another ecu just to blow it again... I do know it happened after I moved the ecu when I was trying to trace my maf problem...
Sideways s12
Car: 84 turbo s12
Ok I have an ecu on the way. My buddy that's good with wiring looked over the harness and said there were no breaks or anything suspicious looking. His assesment is that one of the wires from the depinned maf plug touched the body of the car and that's what caused the ecu to go....
float_6969
That would do it! Well I hope this resolves your issues.
Sideways s12
Car: 84 turbo s12
Me too I think I need a maf though Because I was having maf issues before the ecu went. It was in limp mode wouldn't rev past 2k... I have a z32 maf but no plug for it... and I know I'd have to change the settings on my afc...I just want to get it running how it is now before I make changes...
Sideways s12
Car: 84 turbo s12
I have received my ecu just waiting on the maf to get here so we can get her on the road!
float_6969
Yes! I can't wait to see this thing going... You need to update your sig pic, LOL!
Sideways s12
Car: 84 turbo s12
I can't either and yeah your right I do need to update it. I'm actually getting that car back tho so maybe I'll just add to it.. That one is getting a vh tho I've always wanted a v8.
float_6969
Nice!!!
Sideways s12
Car: 84 turbo s12
full circle replaced the ecu and maf checked the tps and the original problem still exists... Dee says to check the fuel pump which is next on the list... anyody got any ideas?
Issues = runs stupid rich while idling when gas is applied it wants to bog out and die but when you let off the gas it struggles but goes back to idling wideband reads 10.0 while idling then goes 14+ when you apply the gas....
float_6969
Does it have stock injectors in there? And the reason it's showing lean when you hit the gas may be because of rich mis-fires. When you get the mixture much over 10:1, the fuel will fail to start to ignite. When you get a failed to ignite mixture, it will actually show a LEAN situation on the AFR gauge because you have a bunch of air that didn't get combined with fuel. So even though you're rich, it shows lean. Also, have you tried pinching the INCOMING fuel line to reduce fuel pressure and see if the AFR'S come up?
float_6969
Or maybe you have an injector stuck open or leaking? I have a set of stock-looking injectors laying round the garage that I'd be happy to send you for testing. I just had them running my car, so I know they're good, but IDK if they're DET or DE injectors.
Sideways s12
Car: 84 turbo s12
Figured it out afc was bad. yanked it out and the idle smoothed right out and no more rich at idle no I just have to find the boost leak and I think she'll be good.. Thanks for the offer on the injectors but I have a spare set that came with the car...
float_6969
Woot! Glad you got it figured out!
Sideways s12
Car: 84 turbo s12
Ok so fixed the boost leak went to go for a test drive and the god damn waterpump took a s***! smh... I just want to drive my damn car lol I got all the parts to fix it but son of a b**** can something not break this time?
float_6969
You're just working the bugs out man! Keep at it. You'll get there.
Sideways s12
Car: 84 turbo s12
For sure it's just frustrating lol
Sideways s12
Car: 84 turbo s12
AAAAAAAAGGGGGGGGHHHHHHHHH! So fixed the water pump and the rad sprung a leak and my original problem of being in limp mode has come back! I'm about ready to set this b**** on fire lol
float_6969
Codes?
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
This sounds like my experience with mid-90s turbo Audi ownership. "Yay its fixed!" *stranded on the side of the road 2 days later*
Sideways s12
Car: 84 turbo s12
Float no codes. But I'm am pretty sure it's the maf wiring that's the only thing I can come up with on why it's running in limp mode...
R34 yeah this s*** is getting old lol
