Im BACK!!
vboyq
Hey all! i been bak home for the summer(just finished freshmen year of college) where the connection is slow as hell so i don't even bother goin online, well neway, still haven't sold my Honda yet!(Need the money for SR project:help ) Well i just disconnected the speed sensor on my friends honda, so he doesn't rack up miles, and i know the check engine light comes on, but is there any other negative side effects, told him i would tell him tomorrow?
p.s. i know this is the sr20 forum but this is where i always go and i trust the people that post alot here, soooo any help would me muchly appreciated
RobDET
Car: Cars
actuially if the CEL is on you won't get vtec either if the car has it
Also if you disconnected all the transmission wires his reverse lights won't come on either.
(my last car was a 91 CRX HF with B16 it went 14.3@97 with the motor and literaly nothing else at Hattesburg MS)
oah and for all you guys that say vtec doens't do anything i went 15.7 with the vtec solenoid unplugged same track same day same car.
vboyq
all i disconnected was the speed sensor, so as of late nothing has happened, will anything happen.
RobDET
Car: Cars
nothing will break but if the Check engine light is on he won't get vtec. Car will run fine tho.
vboyq
well it is an automatic though, beaing that its not a manual does all the aboove still applly?
minoru
vboyq wrote:all i disconnected was the speed sensor, so as of late nothing has happened, will anything happen.
This is not true I run my 00 gsr with the cel on all the time (cat. problem) and I still have vtec. It really depends on what the cel code is, check the code the car is showing.
blk90s13
W B
vboyq
well im not worried about the vtec, cuz it doesn't have it anyway, im just worried about any mechanical problems that the car might have from not getting any feedback from the disconnected speed sensor and its got a straight pipe anyway, and 1 more thing wats a cel?
RobDET
Car: Cars
ture... the cel from the transmission not being connected will cut vtec... sorry for being unclear.
No mechanical problems
vboyq
o k thanx got it all straight now!
Justice
Car: turbo's
wait you are doing what? not racking up miles so you can sell the car for more? that is ****ed up and i hope thay ban your IP address.
you stupid idiot.
vboyq
y don't u try reading the entire post b4 u say something, ur the one lookin like an idiot, typin b4 u even see the whole thing!
SCOOTER240
Car: 1990 240sx sr20 black top
:confused: negative side-disconnecting any mileage counter is illegal under any circumstances-but on the mechanical side with the check engine light on-depending on how the pcm interrperits the information it could cause the car to run either extremely rich or extremely lean at times-causing damage to various sensors and moving parts-in short it is not advisable to disconnect any sensors-they are there for a reason
mang
RobDET wrote:(my last car was a 91 CRX HF with B16 it went 14.3@97 with the motor and literaly nothing else at Hattesburg MS)
b16a?
RobDET
Car: Cars
yah B16A I'm ROBCRXB16 over at ClubSI i don't post there much anymore...
And the speed sensor in a honda doesn't cause the car to run ritch or lean or anything... it just tells the car it is moving and how fast... unless the car is an auto nothing bad can happen... The Fuel Calculations come from the MAP and the TPS and the O2 sensor... Coolant temp plays a factor before warmup also...
** edit**
been a while sence i read this post...yah if it's an auto it probilby won't shift right... if it does there is still the automatic load detection... don't know what it does but i think it's important (other than whats in it's name)...
I H8 UR DSM
RobDET
Car: Cars
Thanks H8 i needed a good laugh this morning...
I H8 UR DSM
hehe, thats what im here for : )
I H8 UR DSM
I H8 UR DSM
vboyq
RobDET wrote:** edit**
hey so you think i should tell him to reconnect it?
Oh Btw thanx for the helpful input Rob!
RobDET
Car: Cars
I think he should reconnect it caust that is a dishonorable thing to do... however i just can't say exactuially how important it is on an automatic... My educated guess tells me that if the car runs and shifts fine.. and kicks down properly then it should be ok. But i have no experence with honda automatics.
vboyq
ill let him know rob thanx again really appreciate it, and ill tell him the wat u think too ;)
