Cezar718 wrote:can somebody tell me the difference between the timing chain noises in the 240sx and a timing chain gone bad?
Timing chain gone bad, the car wont run, or turn over, and if it does you will hear the wonder sound of the pistons hitting the valves and bending them. kas are interference engines. what that means is that when the valves are fully compressed,"pushed down into the cylinder", they are in the direct path of the piston. so if your timing is off, or the chain is way to sloppy and the tensioners arnt doing their job, you will bend those valves cause the "pushing" is at the wrong time, and the hit.
i know thats was laymans terms, but i hope you get it!!
